Power window help needed
Old Feb 21, 2010 | 07:47 PM
Bertha1's Avatar
Drivers side window is UP. Pass still works/when you hit the switch for the drivers side you hear an audible click but nothing happens. Would it be the window motor or is it just bound? Any suggestions would be appreciated. Thanks!
Old Feb 21, 2010 | 09:20 PM
RotaryRocket88's Avatar
Top Down, Boost Up
Remove the driver side switch, and take out the 3 screws holding it together. Hold the switch upright, then carefully pull the bottom plate off. There are 5 little copper pieces that can fall out if you don't have it upright. Polish these pieces (and the contacts) with some scotchbrite, put it back together and give it a shot.
Old Feb 22, 2010 | 09:51 AM
infernal's Avatar
Watch out for the little springs... They tend to fly off!!!
cam_7779
Aug 18, 2015 07:48 AM
