how low?
Old Feb 18, 2010 | 11:05 PM
silver80sa22c's Avatar
how low?
anyone have any idea whats the lowest i can go on my 85.. 205 50 15 tires rolled fenders... how far can i go without rubbing. thanks, matt
Old Feb 19, 2010 | 01:50 AM
thunkrd's Avatar
i'm a poser
quite low.. but depends on your offsets
i can still lower it quite a bit, this is my "easy to go up my crappy driveway" height
Old Feb 19, 2010 | 07:39 AM
Kentetsu's Avatar
It will also depend on your suspension setup. Need more room for soft suspension, less for firm.
Old Feb 19, 2010 | 10:36 AM
thunkrd's Avatar
i'm a poser
+1, but right now i don't have rolled fenders. mods are coilovers, camber plates, semicomplete big brake kit. in the summer i might switch to 16s (for a better rear offset)
don't run 15x7 +10 if you want to run wide tires under the wells
Old Feb 19, 2010 | 11:14 AM
well guys my offset is +20 so the only springs i can find are 1.4id and my suspension is all stock.. i dont want to do coilovers seeing i dont have the money.. will 1.4 even look better
Old Feb 19, 2010 | 01:51 PM
foothill's Avatar
Your Arch Enemy
Smile
I like those meshies in the back. You did not have them on at the Beryessa drive.
Old Feb 19, 2010 | 06:35 PM
Keeble's Avatar
if your springs have sagged it will probably raise your car even still.
but it should drop it a tad.
i would just do the coilovers. only like $500 shipped
Old Feb 19, 2010 | 09:44 PM
thunkrd's Avatar
i'm a poser
i wish i had them at that time..
Old Feb 20, 2010 | 12:26 AM
thunkrd's Avatar
i'm a poser
i'm pretty sure you'll need camber
Old Feb 20, 2010 | 12:41 AM
Rotarx7's Avatar
hoycee$$$$$
gimme those autobahns!!
Old Feb 20, 2010 | 02:11 AM
thunkrd's Avatar
i'm a poser
chop the springs weld the diff
Old Feb 20, 2010 | 04:32 PM
orion84gsl's Avatar
My 7 is my girlfriend.
Wait a little longer and save, then you can buy the coilovers.
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
Logan Reinisch
44
Sep 17, 2018 12:20 PM
Jmpabon93
Sep 30, 2015 04:57 PM
