Introduce yourself New members post about yourself here...
85 rx7
Old Feb 16, 2010 | 11:08 PM
gunmetal/131313's Avatar
Exclamation 85 rx7
can anyone give me some ideas on a diff for a s3 rx7 with a s513bt in it/the standard one not that great/but would like to keep stud pattern///the car rolls about 5 mtres then locks up
Old Feb 17, 2010 | 11:16 AM
Pele's Avatar
Right near Malloy
You're going to need to open up the diff, it sounds like you may have damaged the ring gear.
How much Horsepower are you running with the S5 13BT engine?
Old Aug 4, 2010 | 06:07 PM
thank you mate you where spot on ring gear and the pinion where real bad pieces of them the size of 50 cent pieces.last i had it on the dyno 255kw at the wheels.fixed now found another to destroy lol
Old Aug 4, 2010 | 06:17 PM
thank you again its nice when someone helps,and gets it right,
Old Aug 4, 2010 | 06:21 PM
i dont suppose u know where to buy a pierburg fuel pump for the tank to the surge tank or what i can replace it with low pressure i think thanks
Old Aug 4, 2010 | 08:08 PM
RX8ME's Avatar
Welcome and good luck doesnt sound fun
Old Aug 5, 2010 | 07:19 PM
wat changing the centre or finding a lift pump.centre was so easy.i changed it cleaned it and it works cant beleive how easy it was
Th0m4s
Feb 26, 2019 02:04 AM
