Eccentric shaft bearing.
Question a friend asked me today, and I'm not sure what the answer is, so here goes.
When a rod bearing in a piston fails, the engine develops a knock and potentially throws a rod onto the side of the highway.
When an eccentric shaft bearing fails (do they fail? I assume it could.), what happens? Does the rotor start destroying the eccentric shaft itself? Does it mess up the housings? I'm uncertain, call me a noob.
~Devon
~Devon
They can fail, but from what I've read they usually fail either by the bearing "spinning" in the bores they are pressed in & losing concentricity or coming partway out the bore, or by the softer bearing face material "blowing by" and creating a huge oil bypass.
If the bearing got mauled enough, you could conceivably get rotor strikes on the side or rotor housings, but before it gets that far you'd probably sieze due to oil starvation.
joel(PA)
Oct 4, 2015 06:07 PM
