Need help: will 17x9 +22 and 17x10 +18 fit FD?
Old Feb 11, 2010 | 08:12 PM
muibubbles's Avatar
Bubblicious DEF.
im looking to buy some enkeis but idk if this offset will work... can i get away with just rolling my fenders or will they have to be hacked pulled, etc..?
rims enkei rpf1
17x9 +22 with toyo r888 225/45
17x10 +18 with toyo r888 255/40
thanks in advance!
-benny
Old Feb 11, 2010 | 08:55 PM
Battle Cat's Avatar
Space cadet
rims enkei rpf1
thanks in advance!
-benny
i Had the exact same wheels and offset.
your going to need a roll and a slight pull to make it work. nothing drastic.
a 225/45 front and 255/45 or 265 in the rear...
heres a pic.. ( i ddnt have a roll/pull on the fenders and no motor)
245/45 front and 275/45 rear
Old Feb 11, 2010 | 09:05 PM
muibubbles's Avatar
Bubblicious DEF.
how much did the roll/pull cost? is it going to damage the paint/ need to be resprayed?
Old Feb 11, 2010 | 11:08 PM
Battle Cat's Avatar
Space cadet
depends, on who you take it too,.,.
well if the person who is rolling the fenders is good, there shouldnt be a problem.. (for the most part)..
Old Feb 12, 2010 | 05:30 AM
aKaTuR's Avatar
hey benny just get a feed wide body Kit ,
ted
.......nice choice of wheels thow.
Old Feb 12, 2010 | 09:38 AM
Battle Cat's Avatar
Space cadet
theres no need for wide body on for those specs..
i plan on running 18x10 +16 front and 18x11 +12 rear on stock fenders.
Old Feb 12, 2010 | 11:21 AM
muibubbles's Avatar
Bubblicious DEF.
man im scared to run them.. i dont really wanna pull my fenders yet... how much does that roughly cost? i dont wanna go get a quote and get massacred by their pricing...
Old Feb 12, 2010 | 11:36 AM
Miata_mx5's Avatar
Wangan Nasty
Depends on your location, and the talent in that area to be honest.
Old Feb 12, 2010 | 12:23 PM
Mahjik's Avatar
Mr. Links
Sounds like you want "the look", but you don't want to do whatever you need to do to get it. If you are scared of making the car fit the wheels, then get wheels that fit the car.
Old Feb 12, 2010 | 12:38 PM
muibubbles's Avatar
Bubblicious DEF.
actually i just got a pretty good deal on those sizes. i think it will look awesome but im trying to see after the expense of all the body work ill have to do if im better off just getting different rims now..
thanks for the help guys
Old Feb 12, 2010 | 12:54 PM
Dudemaaanownsanrx7's Avatar
wannaspeed.com
There is always the baseball bat roll. You can do it yourself for the price of the bat. If the paint is heated there is less chance of the paint cracking.
The wheels above stick out too much for my tastes. I like my tire flush with the fender. 18x10 +16 is really going to stick out..
Old Feb 12, 2010 | 12:57 PM
Mahjik's Avatar
Mr. Links
Looks at StarScream's pictures. His pictures don't show a pulled fender, but you can clearly see the wheels are about 1" if not more out of the fenders. You either need a fender pull or over-fenders if you want to make the car fit the wheels. Or, you can leave them out and drive around as some people like that look.
Personally, I don't see the problem. If you want those wheels, buck up and pull the fenders. It may require a little paint work but that's the price of going aggressive (or making the car fit the wheels).
Old Feb 12, 2010 | 08:55 PM
ARD T2's Avatar
Or just rock
225/45 front and rear so you get more stretch in the rear.
just do a roll in the rear, run some negative camber, and see if you need to do a pull with 225's in the back. From that point you can see how much room you got and at that point can purchase the 255's if they will fit or just get another pair of 225's.
In all honesty I think you will need to do this on a HOT DAY or HOT ROOM. Since you will be working the whole fender and trying to pull you should keep it warm at all times. I'd prop up some heat lamps and use a heat gun.
The rear fender on the FD will pull out pretty nicely due to its shape. I wouldn't do the "drifter" pull, i'd just basically stretch the whole fender out so it still has factory body lines.
Rishie
BLK 93
11
Sep 9, 2015 10:56 AM
