Sponsored by: CARiD
Wet carpet
Old Feb 4, 2010 | 10:26 PM
rare70cat's Avatar
SC Wet carpet
Hey guys, Today while running a new wire for the new fuel pump,I discovered my drivers side carpet was WET! 81 GSL. I have a rubber floor mat so I didn't notice. Any ideas? Previous owner said he cleared the sunroof drains. I took my cowl off and pressure washed all that mess out.
Old Feb 4, 2010 | 10:33 PM
Davin's Avatar
Back door, no babies...
Veteran: Navy
you said 'wet carpet'!
Old Feb 5, 2010 | 12:08 AM
Aerodynamic Pants's Avatar
KS
I haven't had my FB long so I'm not exactly sure where the heater core is,but that might be a possibility. Or perhaps the door weatherstrip?
Maybe a grommet rotted in the firewall and is letting in water?
What about the cowl vents between the glass and hood, is the metal in there solid?
Old Mar 1, 2010 | 11:44 PM
cawcawcacaw's Avatar
i have the same problem, haven't found out where the water is coming from yet in my 83 gs driver side floorboard.
Old Mar 3, 2010 | 07:22 PM
farberio's Avatar
NASA-MW ST4
Also check your clutch master cylinder.
Old Apr 19, 2010 | 01:13 AM
Crit's Avatar
No distributor? No thanks
'If the rear seal on your brake master cylinder fails, the fluid will get through the booster and run down the firewall, right in the footwell. If it's closer to the tranny, then it's likely a failure of the heater core or the coolant hoses that feed it.
Is your brake fluid low?
Old Apr 21, 2010 | 08:15 AM
rxtasy3's Avatar
what's it smell like? then and only then will u know where to start looking.
Old Apr 22, 2010 | 03:40 PM
10yearrx7's Avatar
313 whp 247 wtq 8D
I had this same problem in my fc. it was raining and after I drove only the driver side carpet was wet(and it was soaked). I looked under the car and discovered there was a plug missing. I dont know if 1st gens are the same but it's something I would check out.
Old Apr 30, 2010 | 11:05 AM
ZoominFD's Avatar
Smell? Could be a leaky heater core, or water is getting in there. Are there any holes in the firewall where the water could be getting in from?
Old Apr 30, 2010 | 01:22 PM
rxtasy3's Avatar
not that i know of unless rain water that gets into the cowl doesn't drain out and has rusted out the firewall. or it leaks in around the vent that passes thru the firewall into the cowl area.
Old May 20, 2010 | 11:40 AM
The metal a-pillar cover can channel water to the front part of the door seal. The cover has a little plastic edging around it that can keep the door seal from sealing, which can track water to the interior.
Look carefully when driving in the rain, I had water drops forming on the inside edge of the window frame due to water blowing in - and yes, finding the floorboards wet as well.
One fix is to silicone the front side of that a-pillar cover to the windshield. This cuts down on wind noise as well as the path for water ingress.
