88' vert Exhaust Hangers
Old Feb 2, 2010 | 12:08 AM
elmayimbe4eva27's Avatar
Hello, i have an 88' vert and i'm want to replace my exhaust system. Problem is, apparently the exhaust system isn't using any rubber exhaust hangers, instead the exhaust system is held in place by long welded pieces of metal; so no rubber in between. Does anyone know if i can purchase the metal hooks that belong to the car and then attach rubber hangers to properly install the exhaust system? Would a muffler shop have them or will i have to custom make them? Thanks!
Old Feb 2, 2010 | 06:39 AM
Pele's Avatar
Right near Malloy
Rubber hangers are available from any normal parts store, an exhaust shop, or cheap even from the Mazda dealer...
Is the welded metal attached to the car or the exhaust? Or did they weld the exhaust directly to the car?
Old Feb 2, 2010 | 12:04 PM
They welded the exhaust directly to the car.
Old Feb 2, 2010 | 05:38 PM
RotaryRocket88's Avatar
Top Down, Boost Up
If you're replacing the exhaust with a typical aftermarket system, hooks will be part of the setup. You'll just need to buy stock rubber hangers and to cut the old exhaust system off of the car.
Old Feb 2, 2010 | 10:37 PM
Great! Thats the answer i was looking for! Thanks!
Donald Hampton
16
Nov 23, 2022 06:38 PM
