ebay glow gauges
Old Jan 31, 2010 | 10:39 PM
Sinilluminati's Avatar
ebay glow gauges
will it be hard to install glow gauges from ebay i have an 87 glx rx7 and im changing the cluster faces. any info on this?
Old Feb 1, 2010 | 07:05 AM
David Hayes's Avatar
Like with your other post, it would be most helpful if you posted up a link to the ebay glow gauges.
Old Feb 6, 2010 | 07:24 AM
moosejaw's Avatar
I removed mine
I found over the years they peel away from the face
it was so bad they were preventing me from seeing the tach rev past 4500 rpms
Old Feb 21, 2010 | 07:31 PM
mike_merryguy's Avatar
suck me beautiful
they are not that hard, you just remove the little screws and slide the new face over the needle WITH OUT moving the needle then put the screws back in, kinda a pain to remove the cluster and take the plastic face off but once you get past that its not to bad, kinda hard to see the ODO and TRIP after installing b/c the numbers are white and so are the faces but its not to bad...
The1Sun
Sep 15, 2015 04:45 PM
chiefmg
Sep 10, 2015 07:46 AM
The1Sun
Sep 7, 2015 10:21 PM
