Will larger secondaries cause fuel cut? S5 TII
Old Jan 30, 2010 | 02:20 PM
hosmer's Avatar
Will having larger (880's) secondaries cause fuel cut with an OEM ECU?
Setup is:
91 TII
88 block
streetport
S5 sensors/electronics/ECU (N370)
FCD
Precision SC61/racing beat manifold
550/880 injectors
Has a wideband and SAFC II...running 8.5-9psi
Old Jan 31, 2010 | 09:43 AM
Aaron Cake's Avatar
Engine, Not Motor
Fuel cut will occur regardless on a stock ECU without an FCD at 8.6 PSI.
If you have an FCD, fuel cut will not occur regardless of injector size.
The ECU has no way of knowing what sized injectors you have installed, thus changing injector size will have no effect on ECU operation.
Jun 26, 2016 10:21 AM
imitek
Aug 28, 2015 05:28 PM
armans
Aug 15, 2015 09:08 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
