tan to black suede FD interior project
I am in the process of recovering my tan interior panels in black micro suede. I know its not for everyone but ive always really liked suede interiors. Here are some pictures of parts I have completed so far:
kick panel
sunroof panel
door panel
and some installed pictures
Im out of fabric for now but it was only about $30 in fabric to cover everything pictured. I figure I can have every tan piece covered in black micro suede for about $100. I think I may go back and redo the door panels since I had no previous experience and they were the first pieces I did, the last couple turned out alot better as im figuring out what im doing.
kick panel
sunroof panel
door panel
Looks good, please tell me this isn't the suede from the fabric stores though, otherwise you'll be doing this again in a few years. I was about to do this myself, until i did a fade test. I had a small piece of microsuede paper clipped to a lamp i have with a fluorescent bulb. Fading was visible withing 2 months. Youn need to buy very high end microsuede or real Alcantara to get proper results
Yep, normal micro suede from the store. Ive heard the aerosol sun protector works really well to preserve the color. I think it might be this stuff:
http://www.lck-international.com/lea...e/keralux.html
Did you try anything like that on your test piece?
Or just make sure your windows are well tinted and put up your front window shield when parked outside. I had the gauge hood done by an interior shop and he recommended this.
I think it looks great! Next you should try your hand with a sewing machine and add some red stitching. Keep up the good work and please post pics of the progress.
Lynn
Trending Topics
So how well did the micro suede hold up? Or did you ditch the project? I've wanted to do this for a long time and I have the whole interior out right now so this is the time. I'm just trying to figure out if there is a way to do it without breaking the bank.
Its held up fine but my car is rarely driven and always parked in a garage, so its almost never exposed to the sun for long periods of time. I haven't moved forward with the project at all because I still need to swap to black rear bins and plastics and black carpet before I want to finish the rest of the interior panels.
I bought some upholstery suede, it definitely is higher quality stuff vs the joanns fabric type stuff. I bought it originally to wrap my dash but then realized it would probably be impossible because of the contours. since the center console was an easy gradual contour i gave it a go. came out good imo. I ripped off the stock covering and foam. used dap contact cement to bond a thin "batting" on the console then covered over that with the suede so it has a "slight plush" feel.
82streetracer
Aug 23, 2015 09:28 AM
go buy Alcantara you'll thank yourself later.
