small beads of water on dip stick
Old Jan 24, 2010 | 03:08 PM
pdub214121's Avatar
Newbie
i have 1987 mazda rx7 13b 6 port bp and the engine is back from the shop after bein rebuild ported and water jacket mod. so i go pick up the car from the shop and i notice small beads of water on dip stick is this normal for a bridgeport engine. All so alot of condensation on da oil cap
Old Jan 24, 2010 | 06:34 PM
Pele's Avatar
Right near Malloy
On the oil filler neck, there's a nipple. What's it connected to?
Sounds like a PCV (Positive Crankcase Ventilation) system malfunction...
So long as you warm the engine up, the temperature will boil off the moisture and it won't do too much damage in the short term. But I suggest you look into connecting a PCV valve between that nipple and a vacuum source on the intake manifold.
I forget where the breather filter is supposed to go.
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
SakeBomb Garage
Oct 9, 2015 10:05 PM
dillrx7
Sep 7, 2015 09:38 AM
