Megasquirt Problems using megalog viewer
Old Jan 23, 2010 | 12:48 PM
bschnard's Avatar
Bare Metal Racing
I have been trying to use MegaLog Viewer with MS2, MSextra and Megatune but keep getting error message that the log has invalid rows. We followed the setup instructions in the Megalog viewer help section but still getting the errors. Is there something special I need to set up in Megatune that I might have missed. I have the latest version of each installed. My JRE is up to date.
Also have a tuning issue. At higher RPMs I seem to get an intermittent stumble where looking at my AF seems to suddenly go very lean, then it clears up in a fraction of a second. Any thoughts there?
Old Jan 24, 2010 | 09:02 PM
Eagle7's Avatar
Ask your MLV question here http://www.msextra.com/forums/viewforum.php?f=100. Phil will get you going.
You probably need to get MLV working to figure out the stumble. Does it happen when the secondary injectors start firing?
WyomingTII
Sep 28, 2015 10:32 AM
lnlreaper
Sep 27, 2015 09:59 AM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
