Engine Swap.. can it be Done? good deal?
Old Jun 14, 2002 | 12:51 PM
M.C. Language's Avatar
Ok, i have a place than can get me a ReBuilt 13B Turbo, for about 1300 amaerican.. Is this a good deal?? and if so, would i be able to swap it with my 86 NA??? obviously with the clutch, exhaust and tranny upgrades allready done...
Old Jun 14, 2002 | 12:52 PM
the engine is from an 87
Old Jun 14, 2002 | 01:03 PM
RETed's Avatar
Anything can be done if you throw enough money and resources at it.
You'll need some way of controlling the turbo engine - a stock turbo ECU would work.&nbsp If you're keeping the stock harness, some of the pins need to be rewired.
You'll need to address the downpipe/exhaust and intake/IC "problem".&nbsp I forsee this costing close to $1,000, unless you're going to try and go "cheap" (i.e. non FMIC).
Now, if the rest of your drivetrain doesn't fail and blow-up, then you should be alright.
-Ted
befarrer
Aug 14, 2015 04:18 PM
ashleymiche
Aug 14, 2015 12:59 PM
