What other year door panels will fit a 79?
Old Jan 11, 2010 | 06:32 PM
vj226966's Avatar
GA What other year door panels will fit a 79?
I want to change door panels on my 79.What other years will fit?
Old Jan 11, 2010 | 08:23 PM
KansasCityREPU's Avatar
Out In the Barn
1980 - 1985. You might have to drill a hole for the door pull bolt depending on what year you get, but any first gen door panel will fit.
Old Jan 12, 2010 | 12:14 AM
rxtasy3's Avatar
remember tho, if u get panels off a power window car and ur is manual, i'll have to cut the holes for the window cranks.
Old Jan 12, 2010 | 12:21 AM
mazdaverx713b's Avatar
Have RX-7, will restore
any 79-85 manual window door panels will fit manual window doors.
Old Jan 12, 2010 | 05:01 AM
vj226966's Avatar
Thanks.Thats easy enough.
Old Jan 12, 2010 | 08:13 PM
rotarydude's Avatar
Back in the saddle again
How bad are your original panels if I remember correctly yours is an early car and I could be interested in your original panels.
You can use the power window panels as another member said however do not try to use power window panels from an 84-5 even if you cut the hole for the crank the interior grab handle is in the way
runner83
16
Aug 26, 2015 05:16 PM
