Headlight Not Going Up -1980
Old Jan 9, 2010 | 08:52 PM
Chris1980Rx7's Avatar
Question Headlight Not Going Up -1980
The driver side headlight is not going up when the lights are turned on or when the switch is pressed - the passanger side works fine. Both headlights work, but the passanger side will not go up. I checked the fuse under the dash and it looks good. Any ideas?
I bought this car new in 1980 and it currently has 106K miles - I haven't used it much over the last 20 years other then to keep the fluids moving.
It is all original and everything else on it is working.
Old Jan 10, 2010 | 10:56 PM
AcidAngel7477's Avatar
We're All Fkd..
the headlight motor prolly went out..or the link that prop's the headlight up got disconnected somehow.
:AA:
renjiv2
57
Jan 25, 2024 03:34 AM
FC3S Timmy
16
Oct 3, 2015 01:08 AM
