fd door handle stuck
Old Jan 9, 2010 | 08:41 PM
boyd6906's Avatar
my fd's drivers door handle is stuck closed on the outside from sitting for 8 months and im afraid i might break it. is there any way to get it lubricated and working or do i have to get a new one?
Old Jan 10, 2010 | 06:33 PM
gracer7-rx7's Avatar
needs more track time
Time for a new handle or a good condition used handle. The door handle internals loose lubrication over time and eventually "seize" so you can't open the door from the outside. Forcing it usually results in breaking the handle at the hinges. you can try removing the plastic cover behind the handle on the inside of the window and try lubricating but if its stuck, chances are you just need to replace.
You can find used handles in the Classified section here on the forum or new from Ray Crowe at Malloy Mazda. He gives us discounts. his contact info is in the 3rd gen FAQ thread stickied in this forum
