I am looking to buy an FD but what do you think..
Old Dec 17, 2009 | 12:23 AM
RX_Alex's Avatar
Well finally i found a 1993 rx7 with 103k and apparently the owner said the engineWas rebuilt when it hit 87k miles but that was from the previous owner and doesn’t not have any paper work showing this was done. These are the pros and cons of the car:
Pros:
Engine and turbos have been rebuilt and are in good condition.
Apex'i electronic boost controller
Innovate Motorsports LED wideband o2 sensor/gauge
Apex'i PowerFC ECM tuned by Steve Kan
Boost gauge
Datalogit tuning hardware/software
Dual intake
3" exhaust front to back, comes with converter bypass pipe
Cons:
Paint (clearcoat) destroyed by california sunshine.
Needs tires.
Oil pan seeps oil.
Needs right rear upper control arm bushing.
Headlight covers are broken.
He is willing to let the car go for 5 grand is this a good buy or not? He also told me that it smokes a little when it starts but it goes away. I just wanted to get an opinion from rotary owners to see if there’s a red flag waving or not
Old Dec 17, 2009 | 09:01 AM
mar3's Avatar
Administrator
To me, 5K for an 87K FD sounds like you're not getting the whole story on that car...it's one of those "too good to be true" moments...but let's see what the 3rdgen guru's have got to say. I'm a 1stgen guy, myself.
Mario III
Old Dec 17, 2009 | 09:42 AM
twinsinside's Avatar
An FD with all those listed extras is worth much more than 5k. Smells fishy to me.
Sounds like either the owner has no idea what the car is worth, is in desperate need of cash, or is trying to pull a fast one.
The fact that all of that stuff you have listed is supposed to be on there tells me the owner knows (or should know) the car. How long has he had it?
Paint and tires are simple cosmetic issues that can be fixed when you have the money, oil seepage from the oil pan is a common problem with FDs, bushings on a 15-16 year old car are no surprise and broken headlight covers can be solved with $100 or less.
I'd start with the basics. Read the 3rd gen FAQ's. Get a compression test done on the engine. It is the ONLY way to be sure that the engine is healthy. If the car was tuned ask for dyno print outs (that could be faked though). If you're not familiar with FD's take it to a rotary specialist if there's one near you and have the car evaluated. Since the car has a boost gauge do you get a strong 10-8-10 boost on the turbos?
You mentioned the car smokes when you start it. What color is the smoke? Black or blue smoke is not good, some white smoke is normal after startup due to burning off condensation, but if it persists after the car has warmed up it could be an indication of bad coolant seals. Bad coolant seals can necessitate an engine rebuild depending on how bad it is.
Old Dec 17, 2009 | 10:19 AM
gracer7-rx7's Avatar
needs more track time
Got a link to the ad?
twinsinside had some good input. Read his post and read the Buyer's Guide in the 3rd gen FAQ.
Old Dec 17, 2009 | 12:06 PM
RX_Alex's Avatar
well at first he was selling it for 10 and as time went on he lowered it to 7500 but i offered him 5 and said yea because he said its either the car or the house so in a way that makes sense. Due to struggling with money.
About the smoke its white when it turns on only and goes away thats what i was told because im over in El Paso TX and the car is in Austin. So i asked him a lot of questions about the car which is why i know this.
I know you guys say to get a compression test but i dont know anyone over in Austin that could help me with that. so what do you guys think?
Oh yeah and the car was tuned by Steve Kan...
Last edited by mar3; Dec 17, 2009 at 02:13 PM. Reason: Merged back-to-back posts...
Old Dec 17, 2009 | 01:31 PM
RTRx7's Avatar
Rammer Jammer
I've seen rollers for more than that. Buy it.
Old Dec 17, 2009 | 03:17 PM
fckid45's Avatar
i mean i jus met a guy today at my work that got an fd with a blown motor for 3 grand! i could not believe it. go and drive it see what its running like and compression test it. then go from there. jus dont jump into it cause that is very cheap from what i have seen for fd prices
Old Dec 17, 2009 | 04:29 PM
KKMpunkrock2011's Avatar
dorito powered
I believe rotary performance is the closest professional shop, but there could be others, but they're in garland.
go drive it, get it compression tested (which isn't that hard to do yourself) and read the FA to to see what you should do.
5 grand seems a little fishy, I think it's too good to be true, but people have had luck before.
Old Dec 17, 2009 | 06:59 PM
RX_Alex's Avatar
yea but the car is out of town so i cant take to a rotary specialist because i dont know the area and i dont know anyone from their...
and like said before he was trying to sell it for 10 but sense he really needs the money and all i have is 5, i offered that and said yea... it wasnt the price he was originally asking.....
how could i check the compression my self? without having to take it somewere because if i do go and get it i dont know anyone that would help me do this
Old Dec 17, 2009 | 07:47 PM
vipcivic's Avatar
I think for $5,000 its worth it even if you have to put some money into it, they run good as long as you take care of the motor
Old Dec 17, 2009 | 08:30 PM
bobson_0's Avatar
FD love
FD's are amazing cars.
It would be worth it even if you had some small problems like you mentioned above. If you think you need a new engine I would get a better price.
That is definitely a good price if engine and trans is good.
Old Dec 17, 2009 | 10:21 PM
RX_Alex's Avatar
ok so lets say i do get it would it stress out the engine a lot if i drive it on the highway for over 9 to 10 hrs to get home from where the car is located? can the rotary hack that much road time?
because im thinking about flying up their and driving it home cuzi dont have anything to tow over here thats why
Old Dec 17, 2009 | 11:35 PM
Mazda RX-7 EFINI TYPE's Avatar
Once the engine is in good working order, and you're not beating the crap out of the car, I don't see why that would be a problem. Just be sure to check all your fluids before hitting the road. After taking a test drive I'm sure you'll know whether it'll go the distance or not. Make sure you take a good test drive though, get a little hwy run & what not, make sure there are no cooling problems or anything. Just my 2 cents.
Old Dec 18, 2009 | 12:52 AM
dorito powered
just check all your fluids before taking her on a road trip, I've taken mine on 8 hour trips before without a problem. Go check out the southwest section and see if anyone in the area is willing to help. I'm sure someone is.
For 5 grand, the car is worth it even with a blown motor IMO.
Old Dec 18, 2009 | 03:10 PM
RX_Alex's Avatar
so how could i check the compression my self? could i test it out while im drivin it or something?
Old Dec 18, 2009 | 11:32 PM
RTRx7's Avatar
Rammer Jammer
You're going to need to rent a compression tester from your local auto parts store. Remove the lower spark plug and twist in the compression needle. remove the egi fuse and have someone crank the car while you hold the pressure release valve on the tester. Repeat this for both sides and you should get three even pulses of 90-100 for a good engine. A little less could be alright for a while but it will need a rebuild soon.
Old Dec 21, 2009 | 08:42 AM
dgeesaman's Avatar
It sounds like a possible good deal. I'd value that car around 8k.
The problems are not signs of major issues and can be fixed with a high success rate by a DIY mechanic.
I would search this forum for how-tos on the DIY compression test. Or you could make an appointment with a Mazda dealer local to there and have them do it. I dont' trust Mazda dealers for much on an FD but compression tests are pretty safe territory.
Also do some searching on coolant seal tests. There are a variety of things to look for, but generally it involves inspecting for exhaust gas in the coolant or coolant in the combustion chamber. If the car passes coolant seals and compression test you have a good deal.
David
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
SakeBomb Garage
Oct 9, 2015 10:05 PM
Cameron38
1st Gen General Discussion
Sep 19, 2015 11:45 PM
mulcryant
Sep 9, 2015 05:24 PM
