Turbine shaft size
Turbine shaft size
I have an s4 hybrid turbo using the stock turbine wheel. I've been looking for a new compressor wheel and they all say either big shaft or small shaft. Is the stock turbine wheel considered a big or small shaft? Also just curious what are the actual sizes of the 2 shafts. Thanks.
Standard T3/T4 sized (both have same diameter). Virtually any T3 or T4 compressor will slip onto the shaft. Hybrids are pretty easy to build, you just have to know what to look for when assembling them (like you just can't bolt the **** together, oil passages need opening up and some holes such as a T4 back plate are ever so slightly off. Also wastegate mounting needs some tweaking and adjusting).
~Mike............
~Mike............
[For Sale] Scratch & Dent, Used, and Open-Box Sale!
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
rx8volks
Canadian Forum
Sep 1, 2015 11:02 PM
