Parts for Christmas.
Old Dec 2, 2009 | 11:57 PM
swif's Avatar
Almost back together
CA Parts for Christmas.
Here is a list of parts that I am looking to get.
SR Ultimate II Fuel Pump $499 Part Number FS-10224
EGT temp gauge twin temp Pineapple racing kit. $249.00 phone number 503-233-3878
FD Idler Pulley kit $249.00 Pineapple Racing phone number 503-233-3878
Peak & Hold injectors Bosch type 750cc & 1600 cc top feed (RC Engineering)
Greddy Spark plugs 10s part # GRD_SP-13000150 is the greddy part number o22-3989
Power FC black box
FD Idler Pulley kit $249.00 phone number 503-233-3878
T-stat Lower temp
Fan switch Lower temp
3 bar map sensor
I am hoping to get this stuff with in the next month. The parst that I do not have places listed to buy from, where would you guys recommend to buy them from. Of course good pricing is a concern, but what I think is more of a concern is customer service.
I am also thinking of changing my Tial blow off valve and waste gate to synapse blow off valve and waste gate. What are your thoughts. Is it worth the price to make the change? Will the product prform better for a rotor?
Old Dec 3, 2009 | 12:55 AM
stylEmon's Avatar
FC since 99
Tweak-it racing sells an idler pulley for $190.
Rx7.com sells a very nice fuel pump for $300ish
turblown.net sells the injector dynamics ID2000s ( a much better option)
stay with the stock oem t-stat
A datalogit can lower your fan settings
banzai racing sells the 3 bar map sensor setup
Don't change the bov and wastegate
Old Dec 3, 2009 | 02:35 AM
swif's Avatar
Looked at Tweak-it racing web site. Did not see just the idler pulley kit. Sent chadwick a message.
Contacted turbblown.net about injectors. I am running a Xcessive FD Lower Intake Manifold, CJ Motorsports fuel rail kit, and have a FLOJO injector driver. Asked for more info on the injector, if they have smaller cc injector for primary. Why do you say better option?
Looke at 3 bar set up from banzai racing and will get it.
With the fuel pump I was looking for the Apexi BNR 32 fuel pump, but could not find one, so thought or the SR because I remember reading at a few differnt sites that it is the same pump.
Thanks for your input.
How about the plugs? Wheres a good place to go?
Old Dec 3, 2009 | 02:20 PM
catch-22's Avatar
WATER INJECTION!! and 20 psi. Cant freakin wait.
Old Dec 3, 2009 | 03:16 PM
FCNAred's Avatar
dual egt
https://www.rx7club.com/3rd-generation-rx-7-1993-2002-parts-99/pinapple-racing-dual-egt-gauge-kit-876416/
i'd go bosch 044 in tank and some yourself some money..... and noise. If you get the ID injectors you can sell your FJO box as well.
Old Dec 3, 2009 | 11:32 PM
swif's Avatar
Here is a file on the injectors that were recommened. My question is How lon is the injector runn time on most set up?
To me will we ever see an injector run for 4 - 5 ms to get 1000cc flow on the car?
Old Dec 4, 2009 | 09:19 AM
dregg100's Avatar
here are your plugs
http://thmotorsports.com/greddy/gred.../i-177764.aspx
by "black box" do you mean datalogit? you can get it from rx7.com
if you want a water/meth injection kit i have a nice used one for sale. pm me
Old Dec 4, 2009 | 07:24 PM
swif's Avatar
Originally Posted by dregg100
here are your plugs
Yes the datalogit for the black box. I was thinking the RX7.com, just wanted to see if anyone had ideas of other places.
Thanks for the recommendation for the plugs. I will check it out. As far as AI kit I plane on get one, I just want to wait to see what I can do with my current planes on the set I am doing. I know whern I go to a bigger turbo, or at least to a ball bearing turbo I will get an AI kit for sure.
Old Jan 1, 2010 | 03:40 PM
swif's Avatar
Got most of my money for my parts. Now I just need to start shopping next week!
Old Jan 2, 2010 | 10:52 AM
Jason's Avatar
The one
do yourself a favor and dont waste the money on Greddy plugs. You can get good plugs for about $7 each.
Old Jan 3, 2010 | 11:33 AM
swif's Avatar
From what I have read the Greedy plugs are better the the NGK plugs that are equal. The Greddy is said to last longer then the NGK's and other plugs out there.
What plugs are you recommending and how long will they last?
I am interested.
Heedlessone
288
Sep 16, 2018 07:22 PM
driftfcbuckey
The Bad & Fugly Members
Dec 2, 2015 05:48 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
