Vert ECU compatibility
Old Nov 30, 2009 | 02:38 PM
fcjuan's Avatar
Talking Vert ECU compatibility
I have a 91 vert with a fried ecu caused by water damage. The top is coming off permanently. Which ecu's are compatible? Does anybody out there have one for sale?
Old Nov 30, 2009 | 05:00 PM
RotaryRocket88's Avatar
Top Down, Boost Up
What is the ECU #? S5 Verts will be N352 (California) or N353 (http://fc3spro.com/TECH/FAQ/ecutype.html). I think there is an issue if you try to mix and match the CA and non-CA ECUs. Maybe someone with an S5 can chime in, but I'd just stick with the same # to make sure.
And there is a classified section for any "want to buy" requests.
Donald Hampton
16
Nov 23, 2022 06:38 PM
mulcryant
Sep 9, 2015 05:24 PM
nkuhajda
Sep 7, 2015 04:07 PM
