Microtech Timing lock
Old Nov 28, 2009 | 03:26 PM
radkins's Avatar
Timing lock
I was under the impression that when timing lock was engaged the ECU locked timing at 5 deg ATDC. When I engage timing lock the timing is locked at 0 deg. This is on an LT12 on a 20 B. We have 2 timing marks on the main pulley. have tried to search and am not having much luck.
Old Nov 28, 2009 | 03:35 PM
13BT_RX3's Avatar
The General RE
Have you read through this?
https://www.rx7club.com/microtech-111/timing-874145/
Old Nov 28, 2009 | 05:44 PM
radkins's Avatar
Yes, they talk about locked timing being -5. When I lock timing in the Microtech it reads 0.
Old Nov 28, 2009 | 09:45 PM
rx72c's Avatar
Top Answer: 1
Yes the microtech locks at zero. Its not at smart as other ecus.
So you set the microtech "0" at -5 on the pulley and you always work out all your timing figures on the ecu -5.
Hope that makes sense.
So if the ecu says your running 21 degrees of timing, your at 16 on the pulley.
Old Nov 29, 2009 | 12:15 AM
radkins's Avatar
A little. We lined up "0" at the right timing at the right mark, or on the spark plug side. So your saying all my timing will be 5 deg behind? Why wouldn't they program the rotary to lock on a timing mark. I tuned a mustang the other day and the microtech locked timing at 10 deg advance and we lined that up to the 10 deg btdc mark. It was easy.
Old Nov 29, 2009 | 05:58 AM
rx72c's Avatar
Top Answer: 1
Microtech will always lock to zero degrees of timing regardless of engine setup. I CAN ASSURE YOU THIS 100%
Old Dec 1, 2009 | 11:30 AM
radkins's Avatar
No sir, sorry but you are 100% wrong. I just went out and double checked, it locks to 10 deg on the mustang with the LT-10. I would take a screen shot, but my tuning computer doesn't get on the internet.
Old Dec 1, 2009 | 12:10 PM
hondahater's Avatar
spending too much money..
I've got a racing beat pulley and mine locked right on the "0" mark of the pulley.
Old Dec 2, 2009 | 02:53 AM
rx72c's Avatar
Top Answer: 1
Your static timing is on 10 or your timing trim is on 10.
Every microtech i have seen locks to zero.
if yours dosnt. Well its a first for me.
Old Dec 2, 2009 | 05:23 AM
lousrx2's Avatar
Your right rx72 the microtech locks at zero you are the man.
Old Dec 6, 2009 | 12:04 PM
radkins's Avatar
Well, technically if you have positive static timing or timing trim values Microtech WILL lock to something other than 0.
I will have to go back and check the static and timing trims, but it was a factory map. I am back in the states and the car is in the Caribbean, so I will check next time I go. I know there was no 10 deg timing trim cause the timing was logging exactually what I had it set at. I am still getting to know the Microtech and never looked at the static timing.
So that leads me to a question....why wouldn't you set a -5 deg timing trim and lock the timing to an actual mark, then erase the timing trim and you timing will be actual instead on trying to subtract from the computer values? That would make much more sense to me.
Old Dec 6, 2009 | 07:00 PM
rx72c's Avatar
Top Answer: 1
You cannot lock a - timing trim
Old Dec 6, 2009 | 09:20 PM
radkins's Avatar
Damnit!
Th0m4s
Feb 26, 2019 02:04 AM
Jutta_J
Mar 25, 2017 11:24 PM
diabolical1
30
Jan 30, 2016 05:50 AM
