GT35R w/ Tial V-band Turbine housing .82/1.06 AR
Old Nov 15, 2009 | 07:37 PM
eyecandy's Avatar
I was curious if anyone has used the Tial V-band turbine housing on the GT35R. Or if anyone has and idea how it flows/spools compared to the T4 divided or undivided housings. Maybe someone form Aspec could chime in? Thanks!
Old Nov 15, 2009 | 07:44 PM
Turblown's Avatar
Turn up the boost
I bet they are 0.10 a/r smaller than their standard counterpart just by looking at them. I could be wrong though. I haven't done any back to backs..
Attached Thumbnails GT35R w/ Tial V-band Turbine housing .82/1.06 AR-tial_turbine_housing_001__640x480_.jpg
Old Nov 15, 2009 | 11:54 PM
Trots*88TII-AE*'s Avatar
4th string e-armchair QB
It's tough to compare them to Cast by looking at them, since they are machined to have 1/3rd less material. Besides, I'm sure if they are stating 1.06 A/R, it's because they've done the internal measurements/design.
Old Nov 16, 2009 | 09:58 AM
Zero R's Avatar
Just in time to die
They are actually 1.03's not 1.06's, kinda funny because they initially were 1.02's , they are T3 volutes not T4 They flow slightly better than their cast equivalent T3 housing if all things a equal. Meaning a .82 TiAL will flow better than a .82 cast Garrett T3. We've done a few, for different framed turbo's and applications. Same goes for the 42R framed stuff it will flow slightly better than a T4 but it will not out flow the T6. Look at the housing it was meant to replace and that will tell you pretty much where your at.
~S~
Attached Thumbnails GT35R w/ Tial V-band Turbine housing .82/1.06 AR-t-manifolds.jpg
Old Nov 16, 2009 | 02:18 PM
ScorpionT's Avatar
Originally Posted by Zero R
They are actually 1.03's not 1.06's, kinda funny because the initially were 1.02's , they are T3 volutes not T4 They flow slightly better than their cast equivalent T3 housing if all things a equal. Meaning a .82 TiAL will flow better than a .82 cast Garrett T3. We've done a few, for different framed turbo's and applications. Same goes for the 42R framed stuff it will flow slightly better than a T4 but it will not out flow the T6. Look at the housing it was meant to replace and that will tell you pretty much where your at.
~S~
Thats what Ive also seen from in my experience, that they flow a bit better.
I believe the T4 divided housings would flow better than the V band. Spool should also be better on a rotary with the divided T4.
Old Nov 16, 2009 | 03:40 PM
eyecandy's Avatar
~S~
I am kinda confused, at first I thought it was T3 < TiAl vband < T4 but then you talking about the 42R it sounds as Vband would out flow the T4? Or is that because the 42R should have a T6, like the 35R should have a T4 for rotary powered cars.
I guess flow and spool are main difference; any of them t3 or t4 frame or the vband should suit my power needs, as the most HP I would be looking for is 400. I like the fact of a vband, I have yet to have an issue with those sealing, and plus no need to purchase any replacement gaskets.
The picture you posted of the manifolds, what size turbo are they for? I particularly like the upper left (short runner) would this work with a GT35R Tial Vband? and does the turbo placement allow me to use the air pump?
Old Nov 17, 2009 | 08:32 AM
Zero R's Avatar
Just in time to die
TiAL replaced the T4 housing on the 42R I was given the impression it was because they felt it was geared more towards their market.
The upper left and lower left are both the same manifold with different runner diameters, both have the same turbo placement. Neither would allow for the airpump to be retained. Though we are working on a different airpump solution.
~S~
Old Aug 17, 2011 | 08:17 PM
The Rush's Avatar
MOB Status
I have the Tial .82 housing. Spools sooo fast. Really awesome quality. Im moving up to a 1.06 because the .82 is just not doing it up top for me.
Old Aug 22, 2011 | 04:17 PM
TrentO's Avatar
I have the 1.03 Tial on a GT35R. I love it. It spools just as quick as my T4 did and might have a bit more power. After getting annoyed with T4 flanges warping from the hour long road race sessions, I went with the Tial. They flow exceptionally well and weigh less than 1/2 the cast iron T4's. Add to that, the ability to clock the turbo left/right and you have a real winner. I'd suggest them over a T4 any day.
My track tested $0.02
-Trent
Old Aug 23, 2011 | 11:23 AM
-Trent
X2. . .get that tranny fixed. . .sell me the FD. . .
Clacor
Sep 11, 2015 08:36 PM
