porting questions
Old Nov 6, 2009 | 12:26 PM
86RotaryRx7's Avatar
Rebuild my Rotary
PA porting questions
do u have to port the engine when you rebuild it? if so whats the best porting i dont want a bridge port i want something a little friendlier to gas mileage. any helpful information would be appriciated. thank you.
Old Nov 11, 2009 | 01:00 PM
sashanos's Avatar
just get a mild street port. you gain the HP but your fuel consumption wont be effected badly just make sure you dont run your engine lean
Old Nov 11, 2009 | 01:28 PM
rxtasy3's Avatar
no u don't have to port it when u rebuild it. keeping the stock port will yield the best mpg. enlarging the ports will leave u needing more fuel to go with the increased air coming in due to porting.
Old Nov 11, 2009 | 09:16 PM
ByeByeSti's Avatar
i second this; mild streetport is the way to go.. im also doing the same with mine, its currently in rhode island being rebuilt and getting a streetport. i didnt want to go with a full bridgeport; those ports are more for track use and they dont exactly help the life span of the motor..
Old Nov 11, 2009 | 10:01 PM
Gurew's Avatar
depends on what you want out of your motor/car....mild streetport for most applications...but i wouldnt suggest you do this yourself as there are many things you shouldnt do that will greatly impact how your motor runs....
Old Nov 12, 2009 | 03:50 PM
Rebuild my Rotary
PA
Thank you.
hotshot2014
Jul 18, 2017 02:30 PM
