Fuel Set Up
Old Nov 4, 2009 | 09:50 PM
David210FC3S's Avatar
Fuel Set Up
I am setting up my fuel system for a car that will be drifting and am looking for pointer on the best way to do it. It will be for a 1990 RX7 vert.
Old Nov 5, 2009 | 10:20 AM
RotaryRocket88's Avatar
Top Down, Boost Up
The fuel system will be dependent on the engine needs, not whether you're sliding through corners. Turbo? NA? Ported? Stock?
Old Nov 5, 2009 | 10:26 AM
13BT Streetported with a Garret t04 turbo
Old Nov 5, 2009 | 10:28 AM
Top Down, Boost Up
Any idea what the compressor wheel is, or what the power potential is of the turbo? There are tons of different 'T04' turbos.
Old Nov 5, 2009 | 10:32 AM
Well i just recently bought the car so i am still trying to figure it all out but the guy that i bought it from said it did 409 on the dyno.
Old Nov 5, 2009 | 10:35 AM
I do know i have 1300cc secondary injectors but was thinking of taking those out and putting in 1600cc. But i dont know what kinda primary injectors i should put in.
Old Nov 5, 2009 | 10:38 AM
Top Down, Boost Up
Hmm. Maybe a T04B 60-1 or a T04E 60-trim? Just guesses really, but both of those turbos are good for around 400 whp. http://www.fc3spro.com/TECH/TURBO/compmap.html
If the car put down that kind of power, and the previous owner didn't remove anything, you can assume the injectors/pump/ems were upgraded to match.
Jun 26, 2016 10:21 AM
