Help?
Old Oct 21, 2009 | 06:41 PM
Barnett87GXL's Avatar
< SPACE FOR RENT >
Question Help?
Hi, I was wondering how do I wire a fuel cut off switch. My brother has one on his rx7 and it is very helpful and stops the engine from flooding or makes it very easy to get it started after it is flooded.
Old Oct 22, 2009 | 09:16 AM
Aaron Cake's Avatar
Engine, Not Motor
Pop open the Haynes manual and look up the wiring diagram for your year of car. Find the signal wire from the AFM to the fuel pump relay under the dash (might be brown?) and put a switch in series with it.
Or, fix the problem causing the flooding in the first place.
Old Oct 22, 2009 | 02:00 PM
diabolical1's Avatar
stock fuel pump?
what plugs are you running?
when was your last tuneup?
Old Oct 22, 2009 | 08:32 PM
< SPACE FOR RENT >
thanks for the help, i got it done.
