shifter has no return-to-center spring loading. Normal?
Old Oct 20, 2009 | 02:02 PM
bondospecial's Avatar
Hi guys, I am a new member. I am an American car gearhead that is venturing into the world of rotaries. I currently own a 2003 Mercury Marauder, a 2004 Taurus SEL, a 1976 Firebird that I just got on the road with a 350 chevy w/ retrofit roller cam that I built for it, an 88 K1500 that I swapped a forged '67 327 engine into, and now the 87 RX7 non turbo.
The RX7 has one of the cheap $29 ebay short throw steel shifters in it. Unlike any other manual transmission car that I have ever driven before, this Rx7 with the aftermarket shifter, is not spring loaded towards the 3/4 shift gate. This makes it very difficult to differentiate between each gate of the shift pattern.
It does not look like there are any return-to-center springs associated with the shifter mechanism on this car, unlike some other cars.
Is there supposed to be a spring assembly internal to the transmission, to keep the shifter in the center position (3/4 gate)?
Old Oct 20, 2009 | 03:51 PM
RotaryRocket88's Avatar
Top Down, Boost Up
It is supposed to have one. Whoever installed the short shifter probably removed it for some reason. Take a look here under "shifter bushings": http://www.mazdatrix.com/g4.htm.
Old Oct 20, 2009 | 04:13 PM
thank you! I am ordering it right now. I can't stand driving the car without it
Steve
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
befarrer
Old School and Other Rotary
Oct 5, 2015 03:30 AM
