Rotary Drag Racing The place to post your racing stories and info
My small FD set up.
Old Oct 18, 2009 | 04:15 PM
MOBEONER's Avatar
It's finally reliable
My small FD set up.
I was just wondering what is an expected 1/4 mile time for my small set up.
I am building my FD for drag racing and highway pulls. right now i am just a light weight fellow no ernieT or anthony NYC power.
set up:
stock port engine
rich mans non sequential with larger flapper.
PFC
850cc-pri
1300cc-sec
FPR
dual stock FD fuel pumps
Coolingmist water/meth injection
greddy 3 row front mount I/C
no p/s....no a/c
4.10/ clutch type T2 lsd
solid motor mounts and solid diff mounts with Garfinkle engine torque brace.
premix
as of now i don't know what rear tires to use and most likely i will contact enzo to tune the car for me. what is an estimated 1/4 time i should expect with this small set up.
Old Oct 18, 2009 | 04:44 PM
catch-22's Avatar
How much boost you running?
Old Oct 18, 2009 | 04:56 PM
R3AL.CH1CK3N's Avatar
Jesse
Veteran: Marine Corp
get a diff and trans brace.. it will help alot. nice setup btw.
Old Oct 18, 2009 | 05:22 PM
MOBEONER's Avatar
I will try to push 15 psi since the stock turbos are weak.
Old Oct 18, 2009 | 06:03 PM
catch-22's Avatar
hard to tell cause every car is different and every tune is different, but back when i was on twins i had a fmic, pfc, intake, dp, mp, and cb and made 298 at the wheels on stock boost. So with your setup i dont see a problem with you making 340-50 ish.
Old Oct 18, 2009 | 08:24 PM
SPEED_NYC's Avatar
RX-Parts
I'm gonna pretend not to be offended when you refer to anthony_NYC power as anything other than "small fellow " power
you know there are stock motors out there making 709 to the wheels right?
Old Oct 18, 2009 | 09:21 PM
13B-RX3's Avatar
7s before paint!!!
Only one way to find out
Old Oct 18, 2009 | 09:29 PM
turbo10th's Avatar
Mid to low 12's depending on driving, 60', and traction. I would say real high 11's if you were on a radial of some sort and cut a real good 60'. I cut a 12.6 with 320rwhp with a 2 something 60' and spinning on stock turbos.
Old Oct 18, 2009 | 09:42 PM
Gohan3rdrift's Avatar
Movie Star
Old Oct 19, 2009 | 10:40 PM
MOBEONER's Avatar
I could have said roan power but i have only seen your car twice since the flushing meadows NYRA days.
streetlegal?
Mar 17, 2022 02:46 PM
Jun 26, 2016 10:21 AM
