Terrible shaking
Old Oct 18, 2009 | 03:19 AM
Chris90rx7's Avatar
UT Terrible shaking
So a few days ago my car started vibrating just a wee bit as I got up to speed in the higher gears, I had to be going 50-60 mph.
I noticed but didn't think much of it until recently when the vibrations got a lot worse.
I jacked it up to see if it was obvious and I found the lower right transmission mount bolt had come almost all the way undone. I retightened the bolt and immediately there was a change, the vibration was almost gone-for about 1 mile.
Then as I got up to speed I notice the vibration once again. I have since jacked up the car and the bolt I originally tightened is still in place. I can't see any other loose bolts either.
I check the oil level and there is plenty.
Any help?
Old Oct 18, 2009 | 10:27 AM
Aaron Cake's Avatar
Engine, Not Motor
Check the driveshaft and inspect the tires.
Old Oct 19, 2009 | 08:11 PM
Chris90rx7's Avatar
Tires okay U-joint looks a little sketchy and I have a cracked oil seal on the rear of the transmission, looks like I have work to do
Sudowoodo
19
Dec 28, 2020 06:30 AM
Jmpabon93
Sep 30, 2015 04:57 PM
xXBrendanXx
Power FC Forum
Sep 17, 2015 10:10 AM
localized
Sep 16, 2015 12:18 AM
