my 87 TII 12.1@116 videos with S5 Hybrid turbo
Old Oct 17, 2009 | 10:23 PM
FC3Sdrift's Avatar
Displacement Replacement
I went to the track today hopin for some better track conditions, NO LUCK!
they did no track prep what so ever, i was blowin my tires off the line, with alittle better traction they were easily 11 second runs
the 3rd run in the video i did manage to get my best 60ft 1.74 spinnin the hell outta the tires first and 2nd gear lol
I got 3 12.1 runs 3 12.2's and a few others
my best time was 12.11@115mph 1.85 60ft
http://www.youtube.com/watch?v=z59ntMloLNY
Old Oct 18, 2009 | 11:17 AM
junito1's Avatar
F**K THE SYSTEM!!
NIce run and nice shifting.
Can u post some of your main mods.
Engine block and turbo specs mainly.
Old Oct 18, 2009 | 01:53 PM
K-Tune's Avatar
FD Daily
what kind of clutch are you using?
Old Oct 20, 2009 | 11:53 AM
FC3Sdrift's Avatar
87 TII chassis
Jdm S5 TII engine
6x 550cc injectors (2prim 4sec)
Garrett a/r .60 hybrid turbo running 16psi(bnr style)
old school greddy FMIC set up
2.5" dp to 3" pipe to 2.5" muffler ( LOL work in progress)
OS Giken twin disk clutch
solid aluminum engine and tranny mounts
apexi filter with 3" TID
KS chipped n374 ECU and AFC neo
worn bf goodrich drag radials 225/45R17's 19psi (heavy bastards)
Old Oct 23, 2009 | 10:39 PM
drifter_sr's Avatar
wow, those are some good numbers. with what you have that is good.
Old Oct 24, 2009 | 08:10 PM
need RX7's Avatar
Listen to King Diamond.
Good numbers!
Old Oct 24, 2009 | 08:40 PM
FC3Sdrift's Avatar
i got a 3" muffler and put it on, it made a pretty big differance. I only got a taste today, but my front has never lifted like it did today, should be easy 11's tomorrow. im gonna roast the hell outta my tires to heat them
i'll post the new vids tomorrow night
Old Nov 8, 2009 | 11:12 PM
gear_grinder's Avatar
Don't hate my V8
what did you tune it with?
Old Nov 8, 2009 | 11:20 PM
Don't hate my V8
i'm dumb, i missed the ksport w/ afc.
NOOb question, whats the tune on the ksport ecu? geniral improvments like rtek or a full retune?
Old Nov 13, 2009 | 07:30 PM
rx7 SE's Avatar
Enthusiast
any idea what your rwhp is? Great runs btw!
Old Nov 18, 2009 | 03:38 AM
ROTARYLiFE7's Avatar
those are some real good numbers. what numbers are you aiming for next?
Old Nov 23, 2009 | 07:44 PM
barney1omm's Avatar
STEP ASIDE !!!!!!!
wats rt ........that 1 bad *** 7 .. also wat hp
Old Nov 24, 2009 | 11:06 AM
1SWEET7's Avatar
Now With 10th AE Fun!
RT is Reaction Time. Nice runs, I can't wait till my local strip opens back up this next year.
Old Nov 24, 2009 | 11:29 AM
barney1omm's Avatar
STEP ASIDE !!!!!!!
i no what rt is ...im asking what his was /lol
Old Nov 25, 2009 | 06:52 PM
Flash's Avatar
re-amemiya body vert
+2 on how you know what knightsports ECU does what? I've had a lot of opportunities to pick one up but no one knows what they do exactly, or how to decipher the tag.
Gear Grinder: It's KnightSports, not ksport. Ksport is a china company that makes low quality coil overs
Old Mar 23, 2010 | 08:51 AM
Don't hate my V8
Originally Posted by flash
+2 on how you know what knightsports ecu does what? I've had a lot of opportunities to pick one up but no one knows what they do exactly, or how to decipher the tag.
Gear grinder: It's knightsports, not ksport. Ksport is a china company that makes low quality coil overs
+1
Old Mar 24, 2010 | 12:58 AM
Boosted11's Avatar
Pistons are gay
Good job! Showing those slow domestics, how it's done.
Old Mar 24, 2010 | 11:35 AM
arghx's Avatar
rotorhead
if it's anything like the FD knightsport ECU, it just adds fuel and pulls timing from their respective maps. eliminates the fuel cut as well.
Old Mar 24, 2010 | 10:07 PM
FC3Sdrift's Avatar
it also has a spark retard revlimiter at 7500rpm programmed in ,
Old Aug 11, 2011 | 10:26 PM
AmviciousRav's Avatar
GTR
you have full interior right?
Old Aug 12, 2011 | 02:01 PM
Clubuser's Avatar
That engine is possessed!!
I'm surprised that much air can be crammed thru that turbine.
What's controlling the 2 xtra injectors? Wired in series w/ the secondaries?
Old Aug 16, 2011 | 09:31 PM
FC3Sdrift's Avatar
full interior and bins with stuff in them
injectors wired series with the secondaries
I run 11.8@119 now
Old Aug 17, 2011 | 11:47 AM
Clubuser's Avatar
Forgot to ask are you using the stock MAP sensor?
If yes, you know the A:F ratio going thru the traps?
Also, do you know the injector duty cycle thru the traps?
Old Aug 17, 2011 | 11:17 PM
FC3Sdrift's Avatar
it was the stock map , with the knightsports chipped ecu
11.8:1
my duty cylcles now are around 70 i dont know what they were before
Old Mar 22, 2012 | 09:10 AM
lorainFC's Avatar
El matatan
real,nice,
