rx7 TII 88 hks turbo timer problem
Old Oct 14, 2009 | 01:23 AM
ion007's Avatar
Newbie
Hi,
I've been using hks turbo timer type-0 for past 2 years and it worked fine, now it won't turn on. I left my lights on yesterday and a cop car needed to jump start my car. Now after the jumpstart, my turbo timer won't turn on at all, no lights or display. Any suggestions?
Old Oct 14, 2009 | 09:54 AM
Aaron Cake's Avatar
Engine, Not Motor
You didn't need to post this three times. Once is enough.
When it was jumped, was the battery connected improperly?
Jumping is actually very hard on cars. I'd suggest disconnecting the turbo timer and leaving it sit for a few minutes, then connect it up and try it again. If that doesn't get it going, it may be fried. If it has fuses (some do, some don't) then check those as well.
Old Oct 23, 2009 | 02:19 AM
ion007's Avatar
Newbie
Hey Aaron,
Your suggestion definitely help! My turbo timer is working again and thankfully it wasn't fried... thanks again.
rotor_veux
46
Jun 12, 2018 10:39 AM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
