RP03 for my 95 RX7
Old Oct 9, 2009 | 06:45 PM
06_aspen_sti's Avatar
Question RP03 for my 95 RX7
I'm looking at a set of RP03 for my 95 RX7. I'm looking to fill up the wheel well. probaby going to go with 18 all around with 8.5 in the front and 9.5 in the rear. I've got stock suspension. Any forseen problems? could i go wider either in the front or rear and still be OK?
Old Oct 12, 2009 | 01:47 PM
ARD T2's Avatar
The only BIG problem I see is that Enkei has not brought in the
18x8.5 +40 offset.
They only have the +30 offset which is more common to the EVO8.
the 18x9.5 +38 is in stock but the front will require a major fender modification.
Just a heads up.
I CAN HOWEVER GET YOU A 18X8 +40 AND 18X9.5 +38. You can run 235/40 and 265/35/18.
Rishie
Old Oct 18, 2009 | 10:22 PM
Rishie
Will that setup require fender mods and do i have to run different aspect ratio's. Can i go with 35's all around or 40's all around?
Old Oct 19, 2009 | 09:52 AM
The aspect ratio is a just part of a function--multiply the width in mm's by the aspect ratio (as a percent) in order to find sidewall height. ie:
Front 235*0.40=94mm
Rear 265*0.35=92.75mm
So you can see the rolling diameter will be almost identical front to rear, and almost the same as stock.
It also should not require fender rolling with those offsets.
Old Oct 19, 2009 | 05:20 PM
ARD T2's Avatar
That's correct and thanks goodfella.
You're good to go, if you like that setup let me know and i'll get em ordered up for ya. Those sizes were in stock when i posted.
Rishie
Th0m4s
Feb 26, 2019 02:04 AM
