Portland DEQ
Old Oct 3, 2009 | 03:29 PM
jinxed4dub's Avatar
Portland DEQ
I'm getting my T2 in the next few days. It needs a new wiring harness to pass DEQ is what I've been told by the PO. Do they do a sniff test on older (1987) cars, or do they plug me in. I think it should pass the sniff test if I do a tune up on her. other than that the car runs drives great. is there ways to help me cheat also. I know derekcat has used MMO or sea foam to help get him through, would this be bad for a T2. I ask because I know you have to be careful to run premium gas to prevent detonation, and wouldn't sea foam drop down the octane?
Old Oct 5, 2009 | 06:14 PM
jinxed4dub's Avatar
Ok somone tell me if its just a sniff test, or do i get plugged in.
Old Oct 5, 2009 | 07:01 PM
shampoop's Avatar
Black 91 gxl
all pre OBDII cars get sniff tested (pre 96)
Old Oct 5, 2009 | 07:28 PM
Derekcat's Avatar
Rotary Zealot!
Not mmo or seafoam... Isoheet [denatured alcohol].
You should go read in the second gen tech section to find out if the same steps apply for T][s and NAs..
On my NAs I need to do this: working cat+air pump output to the split air pipe [the pipe coming from the cat to the exhaust side of the engine bay]+ 1/8th tank of gas+2 bottles of Isoheet in the tank+fill up with normal gas IMMEDIATELY after the test+Disconnect the airpump output from the split air pipe when you're filling up after the test.
and that makes it pass with flying colors.. I remember reading that you need to drive very gingerly while running this setup [do not rev up/use much throttle]
To be clear: I HAVE NO IDEA IF THIS IS, OR IS NOT SAFE FOR TURBO ROTARIES.
Old Oct 5, 2009 | 08:42 PM
Josh18_2k's Avatar
its just a sniffer.
stuff steel wool in your muffler. that will help burn off any gasoline that makes it through
Old Oct 5, 2009 | 11:35 PM
jinxed4dub's Avatar
alright thanks guys. I'll check the 2nd gen section.
Edit: Just searched the 2nd gen section using terms ISOheet, ISO heet. found 4 threads none touched on the topic of Turbo Apps. So if anybody knows let me know.
Mark, you said you use it to pass, have you tryed it on a T2 or your FD's?
Old Oct 6, 2009 | 10:08 AM
barney1omm's Avatar
STEP ASIDE !!!!!!!
boy , i wouldnt pass . lol.
Old Oct 7, 2009 | 12:49 AM
jinxed4dub's Avatar
Ok, would it be safe to create a boost leak with a CAI bypass filter placed before the intercooler, then run the ISOHeet? Would this keep it from boosting?
This is what I'm talking about
http://cgi.ebay.com/ebaymotors/NEW-2...item3a52b38dc0
gabescanlon
NW RX-7 Forum
Sep 24, 2015 11:08 PM
gabescanlon
Sep 15, 2015 06:57 AM
gabescanlon
Sep 14, 2015 12:03 PM
