Sponsored by: CARiD
Hesitation at part throttle cause?
Old Sep 21, 2009 | 06:22 PM
jetlude's Avatar
BadAss DoItYourselfer
Had this problem since my rebuild with medium porting and retune.
Any time , any gear, at about 40-60% throttle at 4500 -5500 rpm massive hesitation. AFR's are in check at about 11.4 at this point and boost will be about 10psi. What could be the cause? At WOT no hesitation at all. Is i lean it a little it gets better, but I afraid to lean ir too much.
Anyone had this problem?
Mods
single turbo
medium street port
aftermarket ecu
1000/1600 staged inj
Old Sep 28, 2009 | 10:13 AM
NoviceRotaryTech.'s Avatar
Home-brew Rotary
Check an adjust TPS, maybe.
Old Sep 28, 2009 | 02:44 PM
diabolical1's Avatar
what EMS? where are your secondaries set to start coming online?
Old Oct 16, 2009 | 05:46 AM
slpin's Avatar
7th Heaven
secondary blades closed at that point? how about the timing?
Old Oct 16, 2009 | 04:02 PM
arghx's Avatar
rotorhead
he has posted about it in other sections, I think it is some kind of an injector staging issue
Queppa
Nov 18, 2024 03:47 AM
Th0m4s
Feb 26, 2019 02:04 AM
Jun 26, 2016 10:21 AM
