Power FC idle stays high when warmed up
Old Sep 7, 2009 | 06:03 PM
LERRY's Avatar
brap brap brap
so my issue is that after my car has been warmed up, the idle stays around ~2000rpm. however, if i turn it off and start it back up in about 10 minutes, it idles where it should (1400) with no problems. however, after driving it around, idle increases to about 1600-1700 instead of 1400. i have a half-bridge 13brew single turbo with all the block off plates, running a pfc with datalogit. TPS and boost sensor are fine, checked voltage and they're within spec. any suggestions? thanks in advance
Old Sep 7, 2009 | 06:39 PM
arghx's Avatar
rotorhead
fast idle system still installed but no coolant going to it?
Old Sep 8, 2009 | 12:56 AM
LERRY's Avatar
brap brap brap
yeah. should i completely remove it or how do i fully disable it? as far as I can see, they aren't connected to anything that will affect the idle..
Old Sep 8, 2009 | 11:44 AM
arghx's Avatar
rotorhead
don't run the fast idle system without the coolant hose or your throttle plates will stick open when the engine is warmed up. you will need to remove the thermowax from the TB, or put the coolant hose back on so the idle drops down once the engine is warmed up.
Old Sep 9, 2009 | 12:21 AM
cewrx7r1's Avatar
Eye In The Sky
Or just screw in the adjusting screw under the wax rod so that it disengages even when cold.
If it will not screw in far enought to disengage, then stick a spacer with a hole in it between the parts to open it more. A small nut will work.
barkz
Power FC Forum
37
Nov 21, 2020 09:34 AM
troym55
23
May 25, 2016 12:42 PM
gxl90rx7
Haltech Forum
Sep 14, 2015 03:09 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
