Naturally Aspirated Performance Forum Discussion of naturally-aspirated rotary performance. No Power Adders, only pure rotary power! From the "12A" to the "RENESIS" and beyond.
EGTs
Old Aug 28, 2009 | 10:38 AM
B6T's Avatar
B6T
ERTW
EGTs
I've began tuning my RX-7 and am wondering what target EGTs are under various conditions.
My setup is as follows:
- Streetported (Mazdatrix template) S5 13B engine, fresh rebuild
- Electromotive TEC 3 standalone - 640cc primaries, 4x RX7 trailing coils fired individually
- 15deg split at 500rpm linearly reduced to 0deg at 8000rpm.
I have a Stewart Warnet EGT gauge with the probe mounted in the rear primary about 1" from the header flange.
I'm currently seeing 800deg F at idle and about 1200-1400deg F under sustained cruise.
I'm interested in hearing what EGTs you guys are seeing. Some information regarding your setup would be appreciated also!
Old Sep 1, 2009 | 10:29 PM
B6T's Avatar
B6T
ERTW
Ok... I'll make it easier for you guys
I'm seeing 1400-1500deg F at 3000-4000rpm light throttle cruise. Too hot? I think I'm going to take 5deg of advance out across the board.
Old Sep 1, 2009 | 11:03 PM
WingleBeast's Avatar
My RX8 runs upwards of 1650 at redline so yours might not be too bad depending on the load. A light cruise isnt that descriptive as far as engine stress. Im not as sure with the fuel maps on the RX7 but on my 8 it will cool down a bit at 4000 when the ports open and the secondary injectors throw more fuel in the engine. If you have a wideband take it a little higher. anything over 1600 at less than WOT would be reason for alarm
Old Sep 2, 2009 | 12:15 PM
j9fd3s's Avatar
Community Builder
try it! from what ive read EGT should almost be highest at cruise
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
immanuel__7
Megasquirt Forum
Aug 22, 2015 09:34 PM
