Install of SPA Techniques dual gauges??
Old Jun 5, 2002 | 05:34 PM
xchaos's Avatar
Anyone have some of these installed? I have a Boost/Temp gauge I am going to install and had a question.
Going to use the temp gauge for the coolant.
Where is the best place to tap for both the pressure and temp sensors in an FD?
For boost, I am thinking on the hard pipe between intercooler and TB. For temp, I am not sure.
TIA
Old Nov 2, 2004 | 09:52 PM
M104-AMG's Avatar
Did you ever get an answer for this ?
Anyone ?
Thanks,
:-) neil
Old Nov 2, 2004 | 10:06 PM
Trout2's Avatar
I have the SPA gauges for water temp/fuel press & oil temp/oil press. I used the stock sensor location (rear plate below the oil press. sender) for coolant. Threads match, just screw in. Stock gauges won't work but it's useless anyway.
The TB elbow sounds ok for the boost sender.
Jack
IB Cristina
West RX-7 Forum
Aug 20, 2015 05:46 PM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
