Big loss of power and rough idle?
Old Aug 19, 2009 | 04:17 PM
treewojima's Avatar
I just got an 87 NA, and everything seemed to be working fine for the first month. Recently however, it has been experiencing a drastic loss of power while driving, and then will idle very roughly. When this happens, I can floor the accelerator and barely reach 3000 RPM. Power will sometimes kick back in after a bit, but not frequently enough for it to be reliable. I've not much experience with cars, much less a rotary engine... do I have a case of the dreaded blown apex seal?
Old Aug 20, 2009 | 06:44 AM
anthonywe's Avatar
check this link (https://www.rx7club.com/new-member-rx-7-technical-256/no-oil-pressure-857169/) it might help you.
Old Aug 21, 2009 | 02:03 PM
treewojima's Avatar
Ack, I just had the engine rebuilt about a month and a half ago... I don't want to go through that again >_<
Old Aug 22, 2009 | 12:34 AM
calpatriot's Avatar
1st two things to check:
1. Trouble codes
2. Closed loop operation
You can make your own code checker from two 12v LEDs and three wires, three spade lugs.
The closed loop check can be done with the same assy.
The check connector is left of the battery, in front of the leading coil. Green, 6 pin female. See the FAQs on how to make and use your own (cheap) code checker.
Old Aug 22, 2009 | 12:37 AM
calpatriot's Avatar
Before you presume drastic internal damage (blown apex seal, etc) I would make darn sure the O2 sensor is working, that the signal is getting to the ECU, and that the ECU is going into closed loop operation (seeing crossings on the 'green lamp' check per the FSM.
Old Aug 22, 2009 | 04:26 AM
Kerberos_8's Avatar
well the simplest thing to do would be do a compression test on the motor if it has compression in both rotors you can rule that out and have piece of mind then do all the troubleshooting.
Old Aug 22, 2009 | 02:49 PM
anthonywe's Avatar
dd compressor test 1 of the was around90 and the other one was around 60??? So i guess that is really bad? How much is it supposed to be? And when you rebuild a motor how much schould the compressure be?
Old Aug 22, 2009 | 03:00 PM
Rotech7's Avatar
Heres a link to a previous post
https://www.rx7club.com/showpost.php...87&postcount=2
Old Aug 22, 2009 | 04:12 PM
anthonywe's Avatar
Ok that helped.. But everytime you rebuild it does it have to have the same amount of compressor after rebuild? If yes what is the amount supposed to be after? So that i can check after i have it rebuild to see if it was done good and with new and not old parts.. Thanks
Old Aug 23, 2009 | 03:24 AM
Kerberos_8's Avatar
90+ in an s4 na motor is fine 60 is really low. If you rebuild then they both should be 90+ and they dont both have to have the exact same compression. so if one rotor is 92 and the other is like 89 that would still be fine.
Old Aug 23, 2009 | 05:52 AM
anthonywe's Avatar
Oh ok cool.. But 1 of the rotor reads like 90 now.. After rebuild it should be more right? Just want to make sure that if i pay this guy to rebuild the whole engine he does not just do the rotor that id 60 and leaves the other one like it is and keep the parts that i payed for it.
Thanks
Old Aug 23, 2009 | 08:29 AM
White94's Avatar
411RWHP
your cars ecu is in limp mode.. check ur MAF sensor .. i bet you this fixes it
Old Aug 23, 2009 | 11:09 AM
anthonywe's Avatar
limp mode.. it goes to that mode by itself? and that can fix a compressor of the motor? don't understand
Old Aug 26, 2009 | 06:47 AM
Kerberos_8's Avatar
he is saying that your car is running in a safe mode that makes it run slow and not accerlerate right. to check your maf sensor first. also just have the guy show you the old parts if he rebuilds its then you know he would have replaced them because you have the old ones on hand.
Old Aug 27, 2009 | 11:47 AM
anthonywe's Avatar
oohhh ok ok nice to know.. yeah I guess but you never know he might allready have old parts from an older rebuild and he can show me that:p.. you know here where I live at people do bad things allot. it is most people that fix car here does bad thing to people and your car. But I guess I will see what happens. thanks
Old Aug 28, 2009 | 03:20 AM
Mizuki's Avatar
this is exactly what is happening to my car right now -_-" were you able to fix it??
Old Aug 28, 2009 | 11:32 AM
anthonywe's Avatar
Well I have had 2 people looking at it. And was told by both that It needs a rebuild. But also people told me that there can be something wrong in the connection in some wires or the secondary fuel injector. That maybe it is not working and cause the secondary one is being used after 4 rpm. But it is good to take a compression test which I did and the guy told me one of the rotor was around 90 which supposed is good enough and not yet needs a rebuild but the second one was around 60 which is pretty low and does need a rebuild. I will have the motor rebuild next week and prob will take a week so I hope in 3 weeks it is done. and If you want I can give you any details about it (anthony_wever@yahoo.com
Good luck with your problem and keep me updated what you do with it.
thank you
Old Aug 29, 2009 | 08:31 PM
treewojima's Avatar
Thanks for all the responses guys, I now have a good starting point for troubleshooting. But how would I go about checking a potentially faulty MAF sensor? Is it something I just have to swap out, or is there a tool I can use? I'm determined to fix this myself now.
Old Sep 2, 2009 | 05:25 AM
siCk FC's Avatar
enthuZiast
Did the MAF fix your problem? I bought my rx7 a week ago and had to take it home a 2 hr. drive home. halfway home on 5th gear my car was not accelerating. I was giving it gas and i was just gradually slowing down. Tripped me the **** out. As i hit 50 to 40 i threw it on 4th gear and got up t 60 then shot back in 5th and everything is cool. Everything has been cool since then. It just tripped me out because it acted up on the freeway like that. Scared the **** out of me. Anyone have an idea of what was going on? i'm sure it's a common problem too.
Old Sep 24, 2009 | 07:25 PM
treewojima's Avatar
UPDATE:
MAF sensor is working properly. I suspect the problem lies somewhere in the fuel line, whether it be a bad spark plug or a dirty injector. Once I get the engine above 4k RPM, the secondaries kick in and seem to work properly, so that narrows it down to the primaries.
Old Sep 29, 2009 | 06:13 PM
treewojima's Avatar
UPDATE:
I checked the TPS with a homemade LED assembly, and only one light turns on (as it should). I then yanked the spark plugs to see what condition they were in; the tips were 100% black. Carbon buildup, I'm guessing (good or bad)? Next up, the fuel filter and injectors.
Queppa
Nov 18, 2024 03:47 AM
alphawolff
Nov 17, 2015 05:57 PM
sYnth.
Aug 17, 2015 07:28 PM
