87 rx7 turbo 2 front rotor only has compression
Old Aug 19, 2009 | 10:52 AM
rx7turbo-ii's Avatar
just got it and it was sitting for 8 years...only the front rotor has compression.... the back one doesnt even make a noise when the plugs out... before i take the motor out and rebuild it i figured i'd ask around and see if its a known problem before i spend money on rebuilding and porting...let me know ... i'm trying the ATF test...
Old Aug 19, 2009 | 06:50 PM
RotaryRocket88's Avatar
Top Down, Boost Up
Your apex seals are probably stuck. You might try soaking them with penetrant, but most likely it just needs a rebuild.
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
