Ecu
Old Aug 17, 2009 | 02:26 AM
FHR91rx7's Avatar
Ecu
i swapped a 91 na into an 88 and was wondering if i could use the 91 ecu in the 88 with out swapping harnesses....
Old Aug 17, 2009 | 10:46 AM
RotaryRocket88's Avatar
Top Down, Boost Up
The short answer is no. The plugs aren't the same shape, and the wires are in all different locations.
The long answer is yes, but only if you cut the plugs off and re-arrange all of the wires. But you're better off using all S4 electronics on the S5 engine, so you can leave the wiring alone.
Old Aug 17, 2009 | 12:45 PM
FHR91rx7's Avatar
thats what i thought but i had to ask... Thank you you have been alot of help.
Erosangel
Sep 18, 2015 10:28 PM
Erosangel
Sep 18, 2015 04:06 PM
