Sponsored by: CARiD
Do all 91-96 13B motor parts interchangable
Old Aug 14, 2009 | 11:17 AM
vipcivic's Avatar
i was wondering if all 91-96 parts off the 13b are interchangable like the rotors,and housings?
Old Aug 18, 2009 | 08:43 PM
farberio's Avatar
NASA-MW ST4
Most every part interchanges, but you can't intermix. IE if you want S5 rotors then you have to use both rotors, the s5 front counterweight and the s5 flywheel/rear counterweight.
What specifically are you looking at doing? Is this n/a or turbo?
Old Aug 19, 2009 | 07:55 AM
djseven's Avatar
Eh
The turbo rotors are interchangable, the turbo housings are also but you need to block off the coolant ports on the S5 turbo housings, if you want to put a 13brew housing in your S5 TII you wont have the coolant ports.
The NA S5 rotor housings work perfectly if you switch the exhaust sleeves.
The NA S5 rotors, NA S5 irons, and TII S5 irons are not interchangeable with the REW(93+) engines.
Other than bearings/stat gears everything else is interchangable.
That should clear it up for you.
astrum
24
Nov 15, 2017 08:44 AM
Professorpeanutrx7
Aug 18, 2015 03:09 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
