Where can i get these fuel lines and is this a common problem????
Hi i have a 1987 2nd gen rx7 non turbo and currenty i have a fuel leak that just accured today. its coming from right in front of the back left tire directly from the four fuel lines running paralel to eachother. does anyone know where i can get these lines or the best way about goin at this problem????? Thank you Nick
from ny
from ny
The metal hardlines or from above at the rubber hose connections? My bet would be the hoses running from the fuel pump, which is right above / to the side of the tire. Pull the cover plate off from over the fuel pump and inspect the hoses. They're probably 20+ years old and in need of replacing. Just make sure you get high pressure fuel injection hose, not low pressure hose for carbed vehicles.
Again, if you mean the rubber hoses, any auto parts store will sell it in whatever length you need. If I had to guess, I'd say the two hoses are maybe 2 feet long at the most.
