no dash lights
Old Aug 11, 2009 | 10:06 PM
89'GTU's Avatar
no dash lights
I had a short in the left front turn signal, and it cut out all my dash lights, its not the fuse. Could it be all the bulbs at once? a burnt out wire? thanx 4 reading...
Old Aug 12, 2009 | 09:38 AM
Aaron Cake's Avatar
Engine, Not Motor
Fried headlight switch.
But you have checked the "room" fuse, right?
Old Aug 13, 2009 | 01:34 PM
White94's Avatar
411RWHP
check the main relay and headlight switch
Old Aug 15, 2009 | 10:57 AM
Aaron Cake's Avatar
Engine, Not Motor
The main relay has nothing to do with it. It is likely the headlight switch, the wiring harness (burned) or just the room fuse.
The1Sun
Sep 7, 2015 10:21 PM
