Spacers on 19" KAHN RSC Rims
Old Aug 9, 2009 | 01:26 PM
Phaz's Avatar
Stickers kill Se7ens
Hi,
Ive currently fitted a RE wide arch kit on the front and rear puts out about 18mm extra on the sides.
Ive got 19" KAHN RSC 2 peice rims fitted and there not flush with the new kit, what spacers would you recomend and whats safe is 25mm too much for 19's?
Falken 19/30/265 on rear and Falken 19/35/235 on fronts
Old Aug 9, 2009 | 02:49 PM
Rxmfn7's Avatar
Do a barrel roll!
We would have to know the width and offset of the wheels.
Old Aug 16, 2009 | 03:30 AM
DK's Avatar
DK
40k worth of fail
Homie... get a board/stick/yard stick/level and hold it up parallel to your wheel face, perpendicular to the ground. Stand it where you'd like the outermost edge of your wheel to be (most likely it'll be your tire unless you're running a decent stretch). Measure the distance between that and where your **** is actually sitting right now and that's the size spacer your want.
1 inch = 25.4 mm
Rotary12Ahead
Oct 29, 2015 03:16 PM
NickNac113
13
Oct 1, 2015 09:25 PM
