Super AFC Area is for discussing the Apexi Super AFC
Super AFC No throttle and 100% AFM?
Old Aug 9, 2009 | 11:36 AM
Shadow102's Avatar
Eneman to the Rescue
I can seem to find anyone who has had this similar problem. I am going to be working on the thing throughout the day trying to solve this but if anyone has any advise i would appreciate it. I recently installed a SAFC into my 1990 convertible the unit turns on and i have set all the settings where they are supposed to be and wired it exactly like it states on 1300cc.com However when i turn the car on it sputters and run super super rich and dies if i dont keep on the throttle. Upon closer inspection i am getting no throttle input (sensor check sits at .030V) also the AFM is stuck at 100% all the time when i go into sensor check in and out both read .004V. I have checked all my wires and everything else and have yet to get any change in all this.
On a weird side not i have also noticed my blower motor no long comes on but that may just be something completely different unrelated to all this.
Any help is appreciated thanks
Old Aug 9, 2009 | 03:01 PM
Shadow102's Avatar
figured it out...went to go check continuity from the unit to the ECU and the plug inside the unit had come half unplugged leaving power ground and rpm still intact but AFM and RPM were not plugged in
The1Sun
Sep 7, 2015 10:21 PM
