Megasquirt Does my map look decent?
Old Aug 6, 2009 | 08:01 AM
zx2cow12's Avatar
Hi guys,
I am about ready to fire up my engine for the first time after the rebuild and i just want to make sure that the map i have made looks somewhat alright, at least to get it up and running. It is a turbo 13b. Any suggestions would be greatly appreciated!
Ian
File Type: zip
Old Aug 6, 2009 | 12:59 PM
nu-rx7junkie's Avatar
you have rotary mode off?
Old Aug 7, 2009 | 01:23 PM
zx2cow12's Avatar
On my end I have it on. Does it appear off in the map?
Old Aug 8, 2009 | 01:52 PM
I loaded your msq and it showed off. But if you have it on its cool. Your running 4 1000cc injectors?
What port? 10 for required fuel seems high for that.
Old Aug 8, 2009 | 02:57 PM
zx2cow12's Avatar
Its a 6 port motor. Yes 4 1000cc injectors. Im not exactly sure what the required fuel should be, when it calculates it it gives me something like 4.7 which i feel is kind of low? What would you start out at with?
Old Aug 8, 2009 | 05:34 PM
I would try like 7 or so. I have 550's in mine now. HBP using 9.4 for required fuel. I just swapped out the 550's for 720's last night. So I plan on trying 7-8. Ill let you know what I get when I can try to run it again. Have you searched required fuel for 1000cc injectors? In the MS forum?
Old Aug 9, 2009 | 04:51 PM
zx2cow12's Avatar
Good thought im gonna do a little research.
Now i would also like your inputs on the timing portion. Being that it is a turbo i was wondering if the timing was a little too high?
killerrx710
Sep 28, 2015 09:13 AM
killerrx710
Sep 24, 2015 10:57 PM
