can anyone give me info on making a roll cage for a fc rx7
Old Jul 31, 2009 | 10:25 PM
PnoyRx7's Avatar
Super-Pinoy
hey im new here but i was wondering if anybody has or knows somthing about putting a rollcage in a 2nd gen Rx ? and where you would weld it too and what do you have to cut. its just that i take my car out to the tracks once in awhile and id feel much safer with one. thanks in advance
Old Aug 2, 2009 | 12:12 PM
airboarder's Avatar
Project X
Roll cages are pretty simple. First you're going to want to rip all your stock plastics out so you can run the cage bars to everything. It either that or cut holes in them and that can get tricky and can turn out looking like crap. After that you going to wanna weld to the rear strut towers where you hook up the rear sway bar. Generally you want to make an X between the rear towers. Then run a bar from each rear tower on the bottom to the firewall or even better cut it and run it all the way to your front strut. Do the same to the top of the strut tower up to the center pillar with a bar running down to lower support right behind the door. Then run the top bar to the forward A pillar and down again to the lower bar that runs right under the door. Do this on both sides and it should come together nicely. Finally just get a front strut bar and everything should be nice and strong. Good luck man.
Old Aug 3, 2009 | 10:27 AM
Aaron Cake's Avatar
Engine, Not Motor
If you have to ask, find someone qualified to build the cage. This is a critical safety device and should not be designed of installed by the inexperienced.
Old Aug 3, 2009 | 07:19 PM
Jakesrail's Avatar
PM me, I can give you the phone number of a guy that does my metal work. good price, and an RX nut. his dad has been building racing RX7's for almost thirty years. he knowshis stuff
thecody59
40
Aug 23, 2015 06:41 PM
BucketsAllDay
Aug 19, 2015 03:41 AM
Frisky Arab
13
Aug 18, 2015 05:30 PM
