20b and everything for it
Old Jul 11, 2009 | 12:38 AM
rotorykent's Avatar
hey guys i just bought a 20b , im making my car a monster and will not except anything under 500 whp!
Old Jul 11, 2009 | 01:48 AM
Chaotic_FC's Avatar
well 500rwhp is not very hard to obtain.. i would not consider that to be a monster with a 20b.. if you really want to make a monster, prepair to spend some money. but a gt55 is a nice match in case that is what you want.
Old Jul 11, 2009 | 02:32 AM
charlies7's Avatar
3rd rotors a charm
There is an abundance of threads in this section to help your research want you want to do and make your car a monster. Do a simple search and see the results that people have made over the years.
Plus you wouldnt want us to tell you what to buy, its your car
Good Luck with the build, hope you have some deep pockets.
Originally Posted by rotorykent
hey guys i just bought a 20b and was wondering if anyone could give me a list of parts and prices, im making my car a monster and will not except anything under 500 whp!
Old Jul 11, 2009 | 07:39 AM
bewtew's Avatar
1BAD20B
+1.
gt55? that's huuuuge! i run a bw s480 on my 20b.. love it.
Old Jul 11, 2009 | 03:14 PM
rotorykent's Avatar
how much power have you made with that?
Old Jul 11, 2009 | 03:19 PM
Turblown's Avatar
Turn up the boost
Gt55, why?
Gt42R is a very good turbo size for the 20B..
15psi is over 500rwhp without breaking a sweat...
Old Jul 11, 2009 | 03:21 PM
charlies7's Avatar
3rd rotors a charm
I'll be running NA with high comp rotors and a race port, hoping to make a high 300whp number.
Old Jul 11, 2009 | 05:30 PM
Chaotic_FC's Avatar
Originally Posted by 1Revvin7
Gt55, why?
because its a 20b. if you want a gt42, you should put it on a 13b in my opinion.
Old Jul 11, 2009 | 09:03 PM
GT55 is overkill for a street driven 20b.....a 42R will give fast spool and plenty of power.
Old Jul 12, 2009 | 12:11 AM
imtiaz's Avatar
what is the difference between a 42r and a 4202r ?
Old Jul 12, 2009 | 09:25 PM
It has a 102mm compressor wheel:
(scroll down to large frame)
http://www.turbobygarrett.com/turbob...ochargers.html
Old Jul 13, 2009 | 12:37 AM
20B in the making
lol goodfella you beat me to it. I was acually going to buy one in about 2 to 3 weeks from now. my best bet is a gt45r its inbetween a gt42r and a gt55. im going to give you an idea of what im going with. GT55, full bridge port, whole motor balanced ( shaft,rotors,), low compresson rotors,6 additional injectors, 4" accufab mustang TB, 3mm apex seals dunno yet have to decide what kind, hardend oversized engine bolts, race bearings. best thing is look for real good apex seals, IM prob going with eather ALS RACING SEALS, PTS APEX SEALS or RA SUPER APEX SEALS the black ones. Thats what i have in my FD right now the 2mm ones and iv had never had a problem with them and i was boosting at 23LBS. If you are wondering who i am im the guy that bought Brians Black FD from Georgia i remember you guys were having some discussion on his forsale thread about you wanting something back lol.
Old Jul 13, 2009 | 12:38 AM
20B in the making
O i forgot to mention pineapple racing sells reusable water seals and iv heard they are very good. Im deff going to go with that.
Old Jul 13, 2009 | 03:17 PM
t-von's Avatar
Rotor Head Extreme
For your hp goals, a GT-40r is a better choice. It will spool faster than the 42r for better bottom end and there is still enough compressor left for 600rwhp if you should decide to raise the boost.
Old Jul 15, 2009 | 01:23 PM
hIGGI's Avatar
i have GT35R, should i even consider putting it on 20B?
not looking for high hp, but for lot of torque and very fast spool....
no more boost than 15psi
Old Jul 15, 2009 | 07:54 PM
Turblown's Avatar
Turn up the boost
No, way too small of a turbine wheel/ and available housings for the 20b. Personally I would only use a T6 flange'd turbo..
Old Jul 15, 2009 | 09:46 PM
Evil Aviator's Avatar
Rotorhead
A medium frame turbo isn't going to work. For a stock ported engine, you would want something that can flow into the 60-70 lbs/min range, such as a T-64, T-66 or GT40R.
This sounds pretty close to what you are considering:
http://www.7parts.com/forums/viewtopic.php?t=12
Old Jul 16, 2009 | 01:23 AM
hIGGI's Avatar
Link you posted is 20B with 9.7 compression ratio na GT40R
Well, what exactly will happen with GT35R on 20B with stock 9.0 comp?
With properly sized exhaust manifold and large enough wastegate (i run HKS GT 60mm right now), i am guessing it should do no big harm to exhaust flow and as well should be no worse in power compared to current setup (15psi on ported S5 block)
Or am i completely wrong?
Old Jul 16, 2009 | 07:45 AM
35R is a 61mm compressor wheel, I'm not sure that the analogy can be made to running a 40mm comp wheel on a two rotor but I'm pretty sure the 35R is all around too small.
Keep in mind the 35R is considered too small by 13B guys looking to make serious power
Old Jul 16, 2009 | 10:21 AM
Turblown's Avatar
Turn up the boost
Gt35R uses a BIG t3 turbine wheel, and generally a T3 turbine housing( ATP sells a T4, but its just a T4 flange on a T3 housing). Most of your flow goes through the turbine, and a big wast-gate can't makeup for too small of a housing. If that was the case we would all run t2 housings with 4x 60mm gates...
If you want to run it like a truck built v8 engine go for it, don't expect any power over 5k rpms...
Old Jul 16, 2009 | 11:33 PM
t-von's Avatar
Rotor Head Extreme
The gt35 has been proven to make 500whp on a 2 rotor and will do the same on a 3 rotor. Only difference is the larger displacement and exhaust energy will spool the turbo much faster for a **** load of bottom end. It will easily feel like a v8 but run out of breath in the upper rpms.
Old Jul 18, 2009 | 10:39 PM
Rotorhead
... which is perfect for making a lot of torque and fast spool.
The smaller turbo will choke and/or blow hot air at the higher engine rpms, and the stock compression rotors will have a bit less low end torque and slightly slower spool but will handle the boost a little better.
Based on the compressor maps and some quick ghetto calculations, it looks like the GT35R will run out of steam around 6500 rpm. As you can see, the GT40R looks much better.
I think the GT35R will have some flow problems if used on a 20B. The narrow boost profile is better suited for a higher-boosted lower-displacement engine.
Attached Thumbnails 20b and everything for it-gt3582r20b.jpg   20b and everything for it-gt4088r20b.jpg   20b and everything for it-gt3582r13b.jpg
Old Jul 19, 2009 | 12:01 AM
PDViper77's Avatar
HAHA V8
I had a GT42R on my Half-Bridge 13B and am going with the same turbo on my 20B. A GT55 would be stupid. Steve Kan had a GT47R on his 20B and told me to stay with the 42R. A GT55 would be super laggy even on a 20B plus when it did spool good luck hooking up.
