FD rims fit on a FC?
Old May 28, 2001 | 11:14 PM
ronnie416's Avatar
Bastardized RX7 Pwner.
Do FD rims fit on a FC with 235 50 17's in the rear?
ronnie from toronto
Old May 29, 2001 | 12:02 AM
SpeedRacer's Avatar
Formula Mazda Driver
well FD rims are 16" so you couldn't have 235/50/17's on them. The stock FD offset is +50mm, the stock FC offset is +40mm. FD rims will fit on the rear of an FC, but you may experience rubbing under hard cornering.
Jeremy
Black 1990 GTU
Mariah Headers
Bonez Racepipe
Bonez Intake(K&N Cone)
Volk Racing TE-37's 16x8's(shipping)
GC Coilvers
GC Camber/Caster plates
Eibach ERS Springs
Upgraded 4-piston calipers
SS Brake Lines
Hawk HP+ Pads
Brembo X-drilled Rear Rotors
Speedbleeders
AC Removed
P/S Steering removed
AIM - OnlyNDrms3268
Old May 29, 2001 | 12:51 AM
ARD T2's Avatar
I agree with speedracer, something doesn't sound right. But if you are asking whether some aftermarket 17;s from an FD will fit an FC, I'd say it depends on the offset. Look at the inside spoke or lip of the rim it should indicate the offset, like et40, or et45. A 38 - 43 mm offset in a 17,8 or 7.5 will work on the FC with a 225/45/17 rotatable.
A 235.50.17 will not fit an FC, but that tire size doesn't sound right for an FD either. But who knows? It's unique that's for sure.
Good luck, Rishie
BLK 93
11
Sep 9, 2015 10:56 AM
kkev.7788
Sep 2, 2015 01:32 PM
