couple questions
Old Jun 29, 2009 | 11:26 PM
drift slut_fd's Avatar
Team HND
couple questions
i got a 93 fd II......1st problem when the car is in gear with the clutch in just idleing...the rpms jump up and down within like 400rpm....but if the car is in neutral it idles fine....fuel problem?????....2nd problem...when i go through the gears and rev it past 5500 i only get half boost on the next gears but if i keep it under about 4500-5000 i get full boost (8.8psi)...checked for boost leaks and dont have a clue other than possible fuel problems...any suggestions would help alot thanks
_Tones_
May 25, 2021 05:37 AM
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
SakeBomb Garage
Oct 9, 2015 10:05 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
