How much PSI?
Am getting new tires for my FD. 731's Bridgestones, and am wondering what kind of PSI should I have them at. For both optimum performance, and good gas mileage?
Thanks!
Thanks!
heres what u do, put 35 psi in it, just to be safe. then find urself a nice clean patch of Pavement, or concrete. and Lay a set of stripes, go back and check them out.
if you see dark lines on the outer edges of the stripes, give it more air.
iff its dark in the middle, light on the outside, take some air out.
keep finessing it till you get a nice even wear patter across the width of the stripes. and REMEMBER that psi, so u can inflate ur tires to the right level.
FYI: my 79 Trans Am, had 245-60-r15s, it takes 45 psi to get an even patch
my 85 K5 blazer, has 32x12.50 LT15s, and those take a whopping 50 psi, i have them at 47 psi now. when u go offroading, take it down to 20 psi, maybe 15...course thats not an issue w/ a 7,now is it? unless ur sorta...nutty.
anywho, good luck bro
chris
Rides:
1979 Trans Am WS-4 (GT car)
1988 RX-7 SE (daily driver)
1985 Chevy K5 Blazer (Off-road)
2001 Subaru Impreza 2.5RS (dad's daily driver)
1986 Trans Am (retired summer car)
"LETS RYD"
http://84377179.home.icq.com/photoalbum.html
chris
Rides:
"LETS RYD"
Uhhh, wow. I'm not too sure about that last prognosis but if it were up too me I'de start out with manufacter recomended and find someone with a pyrometer. You're looking for about 7 degrees hotter on the inside than the outside. Most of the last post is about right though. If it's hotter in the middle you want lower pressure. Visa versa. Also your alignment has alot to do with it.
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
LongDuck
Oct 7, 2015 08:12 PM
